i got gemini firstmix pro dont like mixvibes cross dj which comes with it,started mapping to virtual dj,jogwheels and led lights not mapping can some 1 please help me
geposted Sat 22 Feb 14 @ 8:19 am
Simple MIDI wrapper does not support mapping LED's and advanced MIDI. You may be able to use param_greater to get the jogwheel working, but LED's are not possible. For the controller to work correctly including LED's, it will need to have a proper definition created for it.
To be able to use MIDI controllers and custom mappings, you will also need to purchase the full VirtualDJ Professional. VirtualDJ Home FREE will only work for 10 minutes at a time with controllers to allow you to test them and it's for non-commercial home use only (It cannot be used at gigs where you are being paid.) If you like VirtualDJ, then please support the software and its future development by purchasing it.
geposted Sat 22 Feb 14 @ 11:39 am
