Forum: Old versions
Topic: VDJ & DM2 [MixMan] Controller
Hello Straight to the point 3 Questions,
I was selling my MixMaster (APB-50322-01 DM-2) with no Success, it was just collecting dust, anyhow, just pulled it out the closest once again and thought since I have it, why not just ASK someone that may know how to accomplish this goal I have in mind...
I want to use the DM2 on an Xp machine but I would like to know, How can I use VDJ with this Controller?
will VDJ recognize the controller?
The Xp machine will be set up for Web radio streaming/mixing and just need to mix from Deck \'A\' to \'B\' using the On board Crossfader.
Also, ;) is there a way to use the \"X\";\"Y\" Joystick to control say DSP_Phaser via P1 with return to Zero if the stick is let go.
thanks ;0)
geposted Mon 03 Mar 14 @ 3:23 pm
It should work - it's USB. The only thing is that you'll have to map it yourself. It shouldn't take long though, because it doesn't seem to have many controls.
Each one of them, What looks like (8) "Tabs" on Each platters, are all buttons ;)
K, thank's
Unfortunately this controller does not send full midi. I had published in the past a PC program which would convert the messages however this is no longer supported in the newer versions of Virtual DJ.
Another person has released a much better app which might work however its limited to XP or Vista at the most.
http://www.pdoom.ch/dm2/
