No idea what i have done, but if i have track playing on right deck, load a track on left deck, when i play left deck it changes the BPM (pitch) to match right deck even though i have config options aut pitch matching disabled pitch reset on load enabled.
Am i missing something? it keeps trying to auto sync only left deck, does not do this the other way round. i,e with right deck
also some times a track playing 80 bpm on right deck makes the track on left deck (should be 124 bpm) play at 160 BPM???????
geposted Mon 10 Mar 14 @ 1:00 pm
Try to check your keylocks.
geposted Mon 10 Mar 14 @ 1:13 pm
no key locks on
geposted Mon 10 Mar 14 @ 1:15 pm
Smart_play has been enabled by the sound of it.
Some skins have this accessible to switch on/off or you can use a keyboard shortcut
geposted Mon 10 Mar 14 @ 1:18 pm
You may have 'Smart Play' enabled. Make sure the lock above the play button is not highlighted.
Cheers, looks like it was that, that was bugging me lol
geposted Mon 10 Mar 14 @ 1:19 pm
I'm glad somebody helped you so soon.
I am on my daytime-office-job right now, just having a lunch-break.
geposted Mon 10 Mar 14 @ 1:31 pm
Yes appreciated, i was pulling my hair out
geposted Mon 10 Mar 14 @ 1:34 pm
