I'm wanting to know if there is a way to set up a hamster switch for it or if it's even possible.
geposted Tue 11 Mar 14 @ 1:26 pm
does any one know what a hamster switch is?
geposted Tue 11 Mar 14 @ 4:42 pm
You can map a keyboard shortcut to "crossfader_hamster"
geposted Tue 11 Mar 14 @ 4:49 pm
what will that do? will it act as the old school hamster switch? because when you hit the switch you swap the deck's for your strong hand.
geposted Tue 11 Mar 14 @ 9:43 pm
Did you try his mapping suggestion?
geposted Tue 11 Mar 14 @ 10:33 pm
yes I did, but it only works with flipping the crossfader and not the jogwheels as well.
geposted Tue 25 Mar 14 @ 5:09 pm
