Topic: Better Tempo adjusting on my Vestex Typhoon?
Can someone please tell me if there is a way to have more precise tempo adjustments on my Vestex/VDJ 7 Pro combo? Is it the VDJ software, or is is Vestex' that is only giving me maybe 3-4 tempo settings within a BPM....like within 124 BPM....I am only able to get 124....124.36....124.65...etc ?
geposted Thu 13 Mar 14 @ 11:57 am
The Typhoon has 7-bit MIDI pitch sliders, which give 128 unique steps. For more precise adjustments, try using a smaller pitch range (E.g: 6%)
If you need more precise control than this and/or at a wider pitch range, then you will need to upgrade to a controller with 14-bit pitch capability, such as either the Vestax VCI-400 or VCI-380.
Sweet Thank you, I actually figured it out and have it set at 8% now....thank you so much :)
