I got a mixtrack controller and it came with virtual DJ LE and bought a subscription to content unlimited to get some music. But I cant find anything when I pull up the program for content unlimited or for netsearch. Any ideas of what to do?
geposted Thu 13 Mar 14 @ 7:40 pm
My understanding is that you must be using the latest version of VDJ for ContentUnlimited to work. So if you are using an older version like the one that came with your Mixtrack, then it will not work.
Perhaps someone will correct me on this.
geposted Fri 14 Mar 14 @ 12:57 am
If they took your money for content unlimited, then you should have access. Are you sure you are logged in? Options, internet, log in. It should say connected.
geposted Fri 14 Mar 14 @ 2:35 am
Audio subscription will wok in VirtualDJ v6.1 and later. Video and karaoke subscriptions require a minimum of VirtualDJ v7.4
As above, please ensure that you are logged into ContentUnlimited service. If you don't have access to CONFIG -> Internet tab, then simply searching for a song in the ContentUnlimited (Or NetSearch folder in older versions) should prompt you to log in. If not, then a firewall on your computer or network might be blocking it.
Please see https://virtualdj.com/wiki/How%20do%20I%20use%20ContentUnlimited.html and https://virtualdj.com/wiki/ContentUnlimited%20is%20not%20working.html
geposted Fri 14 Mar 14 @ 6:23 am
