Just purchased a laptop with windows 8. Virtual Pro was loaded successfully, but when I play it through with the Numark (connected to my Mixer) the sound come out very low and scratchy. Anyone have this issue also, and did you resolve it? If so, how???
Thanks.
Thanks.
geposted Mon 17 Mar 14 @ 2:06 pm
Sounds stupid but is the volume too high??
Autogain?
Master level?
Autogain?
Master level?
geposted Mon 17 Mar 14 @ 2:16 pm
Volume is low, and I slowly increase the volume on the mixer til I hear the broken up sound.
Not sure if this is a Virtual DJ software problem or sound card problem.
geposted Mon 17 Mar 14 @ 2:19 pm
are you sure your soundcard drivers are compatible? are they uptodate??
I am running VDJ on Windows 8.1 with no problems.
geposted Mon 17 Mar 14 @ 3:23 pm
Is the sound low and scratchy even if you use the Numark as Default sound card for your computer and use Windows Media Player ?
I would strongly recommend to optimize your computer for best real-time audio performance.. https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
geposted Mon 17 Mar 14 @ 4:48 pm
You say you are using Virtual DJ pro, which version, and why haven't you registered it?
geposted Tue 18 Mar 14 @ 1:46 pm
Can I use 2 dj io cards on windows 8.1 at the same time so that I have 4 stereo out puts instead of just the 2 ?
geposted Sun 22 Jun 14 @ 8:23 am
