Hi
Me and a friend are broadcasting via a shoutcast server tonight but although the mic works live it does not broadcast over the stream send by VDJ? Any ideas?
geposted Fri 21 Mar 14 @ 2:29 pm
Sounds like you are using a Controller with integrated soundcard that analogue mixes the mic to the audio material inside the device.
You need to connect your Line Output of the Controller to a FREE Line input on your Computer.
Then configure the RECORD LOOPBACK in your Audio settings and select the channel and soundcard for the line input.
Greets, Heiko
Greets, Heiko
geposted Fri 21 Mar 14 @ 4:58 pm
