Alright guys I need some help with this...If you use the CDJ 2000 Nexus devices with our beloved VDJ please take a look at this thread and read what I wrote. I am pulling my hair out. :|
https://virtualdj.com/forums/172822/Hardware_Technical_Support/how_to_connect_CDJ_2000_nexus_to_Virtual_dj_pro_full______________.html
geposted Wed 02 Apr 14 @ 5:48 pm
I want to hear your exact problem...
No sound? No HID control? Etc...
Mine works perfectly fine in Serato, Traktor, VDJ, and Rekordbox.
I am in Mac though. If you're in Windows and encountering that ASIO problem then I can't help you with that.
geposted Wed 02 Apr 14 @ 6:26 pm
You want to hear my exact problem....read what I wrote on the other thread (that's why I posted a link). :)
geposted Wed 02 Apr 14 @ 7:07 pm
JayMSY wrote :
I am bumping this thread because I have started using these units on Tuesday nights and last night was a disaster!! :(
New MBP bootcamp Win 7 64-bit VDJ 7.4 8GB of Ram and 512MB Nvidia Ram.
2 USB (3.0?) Ports
1 Thunderbolt (use this for video - HDMI)
1 Firewire
I ran the Pioneer CDJ 2000's through a POWERED hub.
ISSUES
1) The deck functions were reversed (left CDJ was controlling right deck of VDJ - Right CDJ was controlling left deck of VDJ) - I solved this by swapping the ports .. weird but don't think I would have had to do that.
2) For a performance stage show I had to play CDs that the performers gave. After doing this for a while I dragged a video onto one of the decks and the video did not load. At that point VDJ froze. I had to alt, ctrl, delete and kill it via task manager. When I relaunched VDJ the gui was not right...there was no Config or anything. When I pulled the USB cable/Hub Config came back and the GUI looked normal. Shut down..reboot, put USB of CDJs back in...VDJ loads ... cannot find sound cards! Eventually I got it up don't know how but then again before the show ended it froze again and I could not get it back up. I gave up and used the WeGO.
Would really love to use the CDJ 2000's but is there some known issue with the units that cause these issues I described above when the units are taken out of Link mode to use with VDJ?
A Separate issue I had was with video...went from Thunderbolt port to HDMI to plug into the club's HDMI box. The video was splotchy. You could see the different tones. It was NOT crystal clear...looked like crap to be honest. I had the same settings on the NVidia card as the club had on their card...their videos were clear but mine was not.
2 USB (3.0?) Ports
1 Firewire
ISSUES
I have to say to give it a shot on the Mac side.
I have all my 3 Macbooks 15 bootcamped too. I only use the Windows side when doing Karaoke as Mac has library/database issue on Karaoke files.
And I copied your previous post on the other thread so others can also see clearly what your problem is.
geposted Wed 02 Apr 14 @ 7:55 pm
Please dont open new topics for the same issue/subject.
Topic locked
Topic locked
geposted Thu 03 Apr 14 @ 12:47 am
