Need help everyone!!! Got my Hercules rmx2, now loop mode is so much useless, if I set it 4 beats, it loops random beats, sometimes 2, 1/2, 16, it doesn't loop what I required to loop. Need some help. Thanks.
geposted Thu 03 Apr 14 @ 9:19 am
The pads work as follow regarding the loops:
PAD 1: Sets the Loop IN point
PAD 2: Sets the Loop OUT point
PAD 3: Decrease the loop length by half
PAD 4: Doubles the loop length
The encoder also can be used to decrease or increase the loop size.
So as you can see, none of the pads are assigned to a predetermined loop size. Once you've created the IN point, you have to wait the appropriate amount of time to insert the OUT point, otherwise you will indeed get "random" length.
geposted Thu 03 Apr 14 @ 2:14 pm
Thank you so much for helping me. thank you. I will try it our now.
geposted Thu 03 Apr 14 @ 6:42 pm
