Topic: Scratch to the max?
Hi
I'm using VDJ for a long time and I'm very happy with it.
For all my gigs I use VDJ. but if I want to scratch I need to use Serato...
The sound of scratching on VDJ in not good and the latency is very bad...
I use MacBook pro I7 16GB ram + ddj-sx and last week I got the ddj-sz.
I tried all the recommendation I could find on the forums and more...
nothing seems to work.
As VDJ still does not support the SZ and The mapper and definition files that I use are self made, I guess the fault could be mine.
but as for the sx?
can anyone confirm that the vdj + sx / sz can be used for descent scratching?
thanks
geposted Sat 05 Apr 14 @ 7:28 pm
The sound quality of a scratch between a controller versus vinyl is also vast. I've been adjusting my latency, audio setup, etc for over a year now with my denon 3700s and the latency along with sound quality is still not there. It seems when scratching VDJ skips some scratch output.
I'm hoping V8 will be upgraded this, but who knows?
I'm having same issue with vdj....I have the numark mixtrack pro 2 and the pioneer ddj-wego and thought maybe it was just me until a friend was messing around on my controller and noticed it. Both controllers work and sound good scratching on serato but when I try on vdj its so choppy. Need this fixed. I downloaded the registry tool and played with the default scratch latency and still no change....Can anyone help?
