I'm having a problem with cache files skipping. I just started having this problem. It's a very slight skip, but it's the entire way through the song... sounds kind of like a backspin. I don't have any problems with MP3 files or existing cache files. Just new ones. Any suggestions??
geposted Mon 07 Apr 14 @ 9:28 pm
You don't have a content unlimited subscription so how are you using cache files??
geposted Mon 07 Apr 14 @ 9:41 pm
No, I am a content unlimited member. I have the ability to cache files.
geposted Mon 07 Apr 14 @ 9:43 pm
Ah ok. Just noticed everyone's "Premium Member" tag has gone.
Do you get the same skip in te track if you stream it rather than caching it first??
geposted Mon 07 Apr 14 @ 9:54 pm
No, the skips are at different places when I cache vs just loading. I thought it was just a bad file but it does it on every song.
geposted Mon 07 Apr 14 @ 10:05 pm
Do you have an example or 2??
geposted Mon 07 Apr 14 @ 10:16 pm
You mean which songs? Well for example, I tried to cache Dark Horse by Katy Perry. I tried all 10 or however many of the results came up. Every single one had the same problem.... Little skips the whole way through. Several other songs did the same. Long and short, it's been every song I've tried to cache since the problem started.
geposted Mon 07 Apr 14 @ 10:26 pm
Skips are normaly related with the soundcard and/or latency.
https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
Also it is always best to download first the tracks to cache and do the BPM Scan to this tracks or load them onto a deck.
But press just play when they are fully loaded :-)
geposted Wed 09 Apr 14 @ 1:59 am
Does the same thing happen, with different internet connections? Are they only skipping at home, at the club, wired or wireless?
geposted Thu 10 Apr 14 @ 1:21 am
