Is there is way when using any DJ controller, to send tracks from your folders to the Auto Play column and also active the Auto Play button after you have loaded all the tracks, without using the mouse and keyboard. I have the Pioneer DDJ SX controller.
geposted Tue 08 Apr 14 @ 11:13 am
Sure, but you have to map some buttons yourself.
The actions would be:
playlist_add: adds the selected song in the browser to the playlist
automix: to start or stop the automix.
geposted Tue 08 Apr 14 @ 12:06 pm
Thank You
geposted Tue 08 Apr 14 @ 12:58 pm
What command would I use to add the folder to the auto play instead of the single track?
geposted Wed 09 Apr 14 @ 10:17 pm
There is no action to copy a folder into the playlist.
However you could select all the tracks of a folder with ctrl + a and the press the "playlist_add" button.
geposted Thu 10 Apr 14 @ 8:46 am
Okay thanks
geposted Thu 10 Apr 14 @ 12:15 pm
Hello, Could any advise on what 2 buttons on the Pioneer DDJ-SX I could use to map for the auto play , I just mix music I don't use all those pads etc.
geposted Tue 22 Apr 14 @ 2:03 pm
Hmmmm I believe the Grid Adjust and Grid Slide are two buttons that you can change easily if you don't use them
geposted Tue 22 Apr 14 @ 2:29 pm
Ok I will try those,
Thanks
Thanks
geposted Tue 22 Apr 14 @ 9:46 pm
