please....can anyone help me...inbox/reply me with ANY help:
https://db.tt/f0WFnqiV
geposted Tue 08 Apr 14 @ 9:41 pm
Make sure in the setting were it says Jog Mode,reads Vinyl,sometime it will say CD/Vinyl.remap the Vinyl button on your controller for both players.
geposted Tue 08 Apr 14 @ 10:08 pm
they are on vinyl.....I can eventually scratch...and for a while...but at time...it freezes up, as well as spikes my cpu usage...which I know is a whole other problem
geposted Tue 08 Apr 14 @ 10:16 pm
My guess is that you are having some general performance issues.
What is your Operating system ?
does this happen without the other USB devices plugged as well ?
Only on right deck ?
Please try to optimize your computer.. https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
geposted Wed 09 Apr 14 @ 11:43 am
here's a list of my features
https://db.tt/GnXzpLk3
also, it's only on the right deck and does it on multiple computers and without other usb items plugged in
geposted Wed 09 Apr 14 @ 1:12 pm
also I've done everything on the common issues page...even wen tot Ethernet cord for access tried it without internet access (which I PAID FOR AND DO NEED). it's a funny thing this right deck is...as a sidenote I have an IDJ3...it does it with that one as well
geposted Wed 09 Apr 14 @ 1:18 pm
It certainly points to the problem being with the Numark hardware.
Does it on multiple computers
Only on the right platter
Another unit does the same
geposted Wed 09 Apr 14 @ 1:27 pm
went to and called Numark....got updated driver for N4, but, as a lot of people know, the IDJ3 is not supported anymore and the drivers have loading issues...it still works as a plug and play but any updated or older drivers will not load properly
geposted Wed 09 Apr 14 @ 1:37 pm
I fixed the problem guys....here's what happened....
I had a belkin 7 port powered usb hub that I didn't plug in....I only used it as the usb. I also have a powered LaCie external hard drive plugged in. both sat near (not next to) the right platter. I removed the usb hub for a 4 port Targus hub, and moved the external away from the platter. I also changed the outlet that the external was plugged into, just to be sure. Had to restart VDJ a couple of times, but on the third try, the platter works fine. Havent had an issue since the fix. Thanks to everyone.
geposted Thu 01 May 14 @ 8:23 am
