Is there a way to change the background color of the titler banner?
geposted Wed 09 Apr 14 @ 4:34 pm
Unfortunately not. Its yellow or yellow.
geposted Wed 09 Apr 14 @ 4:52 pm
Yes there is by using this plugin. https://virtualdj.com/addons/14744/SBDJ_ScrollText_v2.html
geposted Thu 10 Apr 14 @ 2:57 pm
Joey, he's talking about the titler plug in, not the text, or scrooling text plug in. The titler gets it's info from the tag or file name, you don't have to type anything in. So the yellow background is the only option, in version 7.
geposted Thu 10 Apr 14 @ 3:14 pm
Which I happen to like (the yellow) but the tittler is not yet redone for 4 deck play,only 2 decks.... :(
geposted Thu 10 Apr 14 @ 4:12 pm
According to the v2 thread, the code is
#`get loaded_song 'title'`#which I've just tried and it works - as long as the crossfader is over to the playing side.
geposted Fri 11 Apr 14 @ 6:52 am
Yup. The later v2 uses VDJScript; v1.5 uses the #MACRO# format.
geposted Fri 11 Apr 14 @ 6:55 am
