I had an odd fault this weekend. I was DJing with 2 decks and everything was going fine for about an hour. I dropped a song onto deck 2 and when I hit play the pitch slider moved to the full position. I moved the controller pitch slider to full and back again and the song went back to its normal speed. I pressed cue ready to play the song and when I pressed play again the pitch slider moved again! This happened several times. I switched to 4 decks and dropped the song on to deck 4 and it worked perfectly so I played the rest of the night using decks 1 and 4. I checked the settings and couldn't find anything wrong. Anyone else had this?
geposted Mon 14 Apr 14 @ 4:02 am
Did you check if you had pitch lock activated?
geposted Mon 14 Apr 14 @ 4:12 am
Most likely, you have beatlock enabled to that deck. Check on the 2 Decks default skin in the SCRATCH panel. There are 2 padlock icons (Beatlock). Both need to be grey (off)
geposted Mon 14 Apr 14 @ 11:23 pm
yeah thanks, beatlock is what I ment ;)
geposted Tue 15 Apr 14 @ 3:14 am
