hello,
I look to the shortcut to select and load the next song of my playlist
can someone have have a debut of answer?
regards
fred
regards
fred
geposted Tue 22 Apr 14 @ 2:04 pm
Try that one:
automix_skip
if automix is active, skip the actual song and mix to the next one in the playlist.
automix_skip
geposted Tue 22 Apr 14 @ 3:04 pm
If you are not using automix and are just trying to load into the active deck, then playlist_load_and_remove or playlist_load_and_keep depending on wether or not you want to keep the song in the list after loading or remove it.
geposted Tue 22 Apr 14 @ 4:25 pm
In the mapper area, just type load to pull up the list of commands that may do what you like.
geposted Tue 22 Apr 14 @ 4:27 pm
