Hello all;
I'm new at using VDJ. I came from 14 years of spinning with PCDJ software. I'm presently running XP Pro [yeah I know I should update to win 7]. Is there a way to use VDJ and have the lower desktop task bar visible? All the skins that I use hide that task bar. If I want to toggle to an open document I have to hit the windows key on the keyboard. I'm hoping to run the software and not hide that task bar.
Thanks in advance,
Dave
Thanks in advance,
Dave
geposted Thu 24 Apr 14 @ 12:48 pm
I'm not sure if this is possible and I can't test it. Don't have XP anymore.
What you can do, and what I'm doing at my gigs, is open that document before you open VDJ.
Now you just could ALT+Tab between these two windows. Works for me.
geposted Thu 24 Apr 14 @ 2:46 pm
I think you can keep VDJ in "Restore Down" mode, the box to the right of the "X" at the top right and then just maximize the screen manually.
geposted Thu 24 Apr 14 @ 5:36 pm
Please don't open old threads, your post was leveled and this thread will be locked, thank you.
Locked by AMAHM
Locked by AMAHM
geposted Sat 07 Jul 18 @ 7:49 am
