Topic: song lists removed - Page: 1
Last night my song folders got deleted,what I mean is, underneath where content unlimited files go. If I search the files come up but I like to have a visual, so my question is how can I get my folders back. Hope this makes sense
geposted Sun 04 May 14 @ 7:47 am
are you using a external hd ?
No I;m not.So by mistake I hit delete folder
Try system restore, might work, might not, but worth a try and you can't do any harm.
Also, look in your recycling bin. It might be in there.
Ya looked there,nothin,gotta figure something out,have to bring the noise in about 8 hours
Let me see if I understand you. When you open the Content Unlimited, you see nothing? Is there a + sign there, to open the tree? You do not see Search Audio, Search Video, etc?
all that is there is the content unlimited,video,and my cashe but no way off adding any folders
Are you saying you've deleted your 'on the harddrive music folders' or are you saying something else?
Are your tunes still on your PC?
How about config>browser is everything that should be ticked, ticked?
How about History, can you pull your tracks from there?
ya sorry trying to explain the best I can,the folders are still in the drive but missing when I startup virtual dj, and the option to add files is also gone
I edited my post above, have you checked config> browser that everything is correct there.
Favourites should be checked and perhaps virtual folders, I've just tried switching them off and that recreates the symptoms you've described.
will try that when I get to work tonight,left my rig last night at the club,hopefully that will work
I've got it (I think,)
You've deleted Your 'My Music' folder from your favourites.
what you need to do is config>browser then check the 'show volumes' option this will let you open C drive find your music folder, from there right click it to set it as favourite, then normal service should resume.
That's what I'm talkin about,thanks man, and to all in the community that reached out to help.Will post later for an update
Haha - I think the confusion was you mentioned Content Unlimited in the first post. I like others looked at it and thought you'd lost a folder from there.
Didn't realise it was just a favourites folder.
Hopefully, that works for you though!!
Maybe that's why I don't know what's going on. Did not answer my question, either.
Ahhh,all good,was a little hung over this morning when I posted it.
Sorry man,there is no plus sign for my favorites and when I go to config and click on the fav icon it still doesnt work any ideas
All is good found the folders restored it,going to be a good night now
Not to worry, an invoice is in the post.
91%
