Okay, I think I'm almost done modifying the default mapping config for my BCD3000. The only thing I want to do is map a button on deck A side to select the deck as the active deck and enable PFL on that side, and same with the other. The problem I am running into is when I try to learn that button to the task, it will only perform it successfully once if it even works at all. I'm a little confused on where to go from here, I've read the script wiki and was unable to determine a solution from there due to inexperience with script.
Any help/advice here would be greatly appreciated!
Thanks!
Thanks!
geposted Tue 06 May 14 @ 7:44 pm
it's just "select" if you have a proper definition file or "deck left|right|# select" if you don't
geposted Tue 06 May 14 @ 8:05 pm
but what about 4 deck swaping on vdj8 ?....I've been trying for a while.other than maping a button to deck select 3 and same for deck 4....
geposted Thu 15 May 14 @ 9:30 pm
Ooohyeeeh! I got the best map! well almost,this puppy is Siickk!....
geposted Thu 15 May 14 @ 11:45 pm
