Hi guys
I have a Sony ECM-MS907 mic that I was planning on using with VDJ 7, to do an internet radio show. Unfortunately I cant get the 2 to work together... So I'm thinking that the mic isnt the right type? Its stereo for a start (even though you can narrow the field to a 90 degrees options), but I guess a mono mic would be better.. Currently my station controller hears my tunes fine but not me thru the mic...
I have the correct settings I think, so is it the mic thats not right for the VDJ? The mic works fine, I know, cos I can hear myself back thru the speakers...
Any advice would be great
Thanks
Jelboy
Thanks
Jelboy
geposted Sat 10 May 14 @ 3:53 pm
How are you connecting everything up? Where are your mic and speakers plugged in? What settings are you using in VDJ?
geposted Sat 10 May 14 @ 6:07 pm
geposted Sat 10 May 14 @ 6:57 pm
He has Pro Basic Chuck so he should be ok with a Mic. Chances are it's just a configuration problem.
geposted Sat 10 May 14 @ 7:00 pm
Don't let the title of this video fool you. It has to do with setting up mic use in VDJ. Hope it answers your question.
[youtube]82K3tLoN3hE&list=UUi9uRwdCAs4SKsEJmwjswzg[/youtube]
geposted Sat 10 May 14 @ 7:13 pm
thanks Dan , thought he was le
geposted Sat 10 May 14 @ 8:04 pm
