Topic: [NEWS] VirtualDJ 8 Pre-Release - Page: 7
FOUND A BUG: It seems impossible to index on BPM then KEY like in VJ7.
Also BPM column aligns to the RIGHT, and KEY aligns to the LEFT. It makes it hard to read. VJ7 has the KEY column aligning to the RIGHT as it should.
And when you re-index the column the position select bar goes down 3/4 the way where in VJ7 it goes to the top. I don't like searching for it. Having it at the top of the cloumn makes for faster scrolling.
Please return to VJ7's functionality. It was logically perfect. VJ8 multi-column indexing is screwed up.
love it
angelt99 wrote :
Sorry, you don't have the necessary accreditations to view this page.
The pre-release was for existing pro license users. If you were not a pro user before this release, you may not be able to view the forum.
blckjck
i am a pro user i have numark cue virtual vinyl pro i even dj on virtual dj radio
mabye you have to contact the support then to check the point of view.
You have access to the publice beta if you are a virtual dj pro full user....
RobRoy
yes i was able to download it and when i put my serial # to unlock it virtual dj 8 does nothing stay on the free version
and now i can not go in to nothing it like i do not have the pro version
as i told you...please contact the support, moderator or team member for this.
i can just refer....;-)
RobRoy
ok i will thank u very much for your help
angelt99 wrote :
blckjck
I would have to guess that it is because your forum ID still has the virtual vinyl, not the Virtual DJ Pro
I think that Rob is correct with contacting support.
another good idea might be to use the time limited offer to upgrade to vdj pro infinity using your current licence....
Think about it....so you could kill two birds with one stone...;-)
hUUUUuuuUUuUGE thanx to you guys!!!!
manca la funzione clip back per far girare video a caso mentre suono, inoltre non posso linkare video alle song come facevo nel 7,
Sorry this is an English Speaking Forum
Please re-post your message in English or post in the appropriate language forum. Thanks.
I uploaded the new version of VDJ... Looks great so far! Only problem is that is created a duplicate of every file I have. Now my DB takes up twice as much of my hard drive. How do I correct this or remove duplicate files?
Please help, this is too much work to clean up one file at a time. I have invested a lot of time into building and maintaining my database.
Thanks,
Thanx guys, the sound is great the samplers and very easy to use with the controllers
how can i save the level of the samplers volume just like vdj 7 where everytime you start virtual dj the samplers keeped the same level as you left it.
Hello people of Atomix Productions.
First of all I wanted to congratulate you for the new version of Virtual DJ. I was Testing it for several hours and resulted very stable, but when I wanted to put a video in the background while I did not find the mp3 sounded the video called clipbank effect that allowed me to place videos while mixed audio in both players. Try install as plugins and neither I could run even appeared in the list of video effects. In this version and later, or stay off this possibility is a problem particularly installation on my machine? From already thank you and congratulations
For issues with v8
djdad wrote :
Please use this thread only to post comments and general questions.
If you need to report anything related to the pre-release version (bug,request etc), please use the dedicated forum https://virtualdj.com/forums/75/VirtualDJ_8_Pre-Release_Forum.html , otherwise your report may never reach the development Team ;)
VDJ 8 NEED HELP!
1. Video effects why is there NO text option...( I installed text2d and it does not work properly in vdj8). I have NO camera option either...) Why so few video effects?
2. I have Numark Cue PRO, and I understand this is a FREE upgrade to all pro users, so why can I not remove logo...(It says I need to upgrade)
Thanks,
75%
