Should the DDJ -s1 show up under audio/Cards
geposted Sun 11 May 14 @ 4:42 pm
It will only show up if the configuration was set during the beta testing and software build.
I know a man who will probably know.
geposted Sun 11 May 14 @ 4:46 pm
Thanks you sir
I'm also trying to figure out the jogwheel sensitivity the default is
1.000000 Ok I would like to make it less sensitive how do you change these
numbers? Sorry to sound like an idiot but I'm not that computer savvy would
love to have a slider there
geposted Sun 11 May 14 @ 4:48 pm
Not the controller expert but i think making the number smaller makes it more sensitive.
e.g. 0.500000
But you can try that and if its wrong then change it back and increase it.
Phantom or DJDad are the 'technical' controller experts
e.g. 0.500000
geposted Sun 11 May 14 @ 4:50 pm
@ audio0000
Unfortunately we didnt have available sample units for all the supported midi controllers. So some of them may still not offer a pre-defined Audio Setup. But it can be added in the next update. Please install the necessary ASIO drivers for the unit, create the proper Audio Setup (with Master, Headphones and the ASIO drivers selected from the drop down list) ans post a screenshot of that Audio Setup here. We will sort this very soon.
geposted Sun 11 May 14 @ 4:54 pm
Default=1
2= Increased sensitivity
0.5= Decreased sensitivity
Thanks George - Dan
Thanks George - Dan
geposted Sun 11 May 14 @ 4:55 pm
i need a screenshot of the Audio Setup with ASIO and the details from the right side visible if possible. thanks
geposted Sun 11 May 14 @ 5:09 pm
Ok in v7 my jogwheel sensitivity = 420
in v8 how would you write this out would it be like this 0.000420?
geposted Sun 11 May 14 @ 5:12 pm
No you need to increase it. Try changing it to 2 and then work from there.
If you can sort djdad out the screenshot then he can get the setup organised.
geposted Sun 11 May 14 @ 5:13 pm
That is what I have up top for my audio set up
geposted Sun 11 May 14 @ 5:15 pm
Can you drag out the right hand side - need to see everything in the righthand box. ;)
geposted Sun 11 May 14 @ 5:18 pm
I thought the S1 had its own ASIO driver?
geposted Sun 11 May 14 @ 5:21 pm
this should be easier to see
geposted Sun 11 May 14 @ 5:24 pm
I think the forum is resizing images now.
geposted Sun 11 May 14 @ 5:29 pm
It always did. Anything more than 800pix wide gets resized
geposted Sun 11 May 14 @ 5:31 pm
djdad
Can you see what you need to see sir...?
geposted Sun 11 May 14 @ 5:34 pm
Maybe make a PrntScrn and then edit it down to just the right side then.
Phantom Ok
in v8 I put it to 0.420000
Would that be the same thing....?
geposted Sun 11 May 14 @ 5:38 pm
No. It's different now.
Edit:
420 in v7 = 0.205 in v8 (value/2048)
Edit:
geposted Sun 11 May 14 @ 5:40 pm
