Is that in this skin or is it from another one?
geposted Thu 05 Jun 14 @ 9:42 am
This skin (seventh post on page one by you).
I said it wasn't consistent that it was only in one view, and you said "will see what I can do".
geposted Thu 05 Jun 14 @ 9:48 am
Just spotted another issue with the "right click browser" in this skin:
The horizontal icons along the top are not far enough to the right, as sometimes the file count results don't have enough space.
.....if it's easier, perhaps make the search box smaller to make more space on the left.
geposted Mon 23 Jun 14 @ 3:45 pm
thanks loving the zoom :-)
geposted Mon 23 Jun 14 @ 5:44 pm
Noted - will try and remember next time i update.
Not going to worry for now as it does not affect usability.
geposted Mon 23 Jun 14 @ 6:22 pm
I've moved them across myself now. Beginning to get the hang of this!
geposted Thu 10 Jul 14 @ 1:34 pm
geposted Thu 10 Jul 14 @ 2:46 pm
love the zoom now no more clip art
geposted Thu 17 Jul 14 @ 8:28 am
+1
geposted Thu 17 Jul 14 @ 12:40 pm
This skin already has the option to switch the art off. Press the pin button.
If you haven't got this you haven't got the latest version.
geposted Fri 18 Jul 14 @ 3:22 am
Can someone please make this plugin display numbered(flags) hot cues on the wave form instead of just vertical line. please.
geposted Wed 03 Sep 14 @ 3:49 pm
GREAT SKIN. I am new to virtual dj 8. Turning off cover art and max screen browser are
exactly what I was looking for. Is there a way you can change the "Already Played" browser
icon to something much bolder and noticeable? The default small red line is not easily
visible. This specific change has been requested numerous times in numerous forums
over the last year. You would be a hero if you implemented this. If you don't want to
add that option, can you tell me what changes to make in the skin code to accomplish
this?
Also, how do I know if I have the latest version of your skin? Can it be updated automatically?
this?
geposted Wed 25 Feb 15 @ 12:00 pm
for some reason i can not get this download i keep getting the following message
(Sorry, you don't have the necessary accreditations to view this page.)
geposted Sat 06 Jun 15 @ 7:47 pm
I've checked and can not see a reason why it would be unavailable to you
Try this link: https://virtualdj.com/plugins/?addonid=16712
geposted Sun 07 Jun 15 @ 3:44 am
@DJTouchDan: what would the script be for a browser without the three split panels (info, sideview and folders), with just the browser and the search part?
geposted Sat 29 Aug 15 @ 7:50 pm
Answer:
<fileview>
<pos x="" y=""/>
<size width="" height=""/>
</fileview>
Thanks to Groovin' DJ
<fileview>
<pos x="" y=""/>
</fileview>
geposted Sun 30 Aug 15 @ 9:09 am
I downloaded the browser zoom skin..after download I double clicked on it and a window came up it says installation complete. Doesn't work. I tried moving the file to skins in the Virtual dj folders to folder "skins" and doesn't work. What am I doing wrong?
geposted Sat 12 Sep 15 @ 2:58 am
v1.3.1 (available now)
DOWNLOAD HERE
Included in this update:
Note: Colored Cue points will not be visible in waveforms or song position, a future update will include this.
DOWNLOAD HERE
- Hot Cues now reflect color_cue (requires build 2819 or later)
- EQ text now changes to red when kill is active
- Extended comment field above browser (activate using pen icon on top bar)
- Video screens now always display something (when video active and videoAudioOnlyVisualisation is set)
geposted Tue 19 Jan 16 @ 11:16 pm
How do I find out the current version on the skin I have? For the new version to be active do I have to delete the older version?
geposted Wed 20 Jan 16 @ 9:52 pm
Just download and install. It will overwrite the old version.
You can tell you have the latest version if you have all these icons in the top right of the skin.
geposted Wed 20 Jan 16 @ 10:00 pm
