I was wondering if I can use Loopmasters loops in Virtual DJ 7.4. If so where do I find them in my computer, and I do I get them into virtual DJ. I like some of the commercial loops from Loomasters etc, are they only for Abelton and Traktor? If this is the case please let me know. I would like to see virtual dj produce or make available loops like they offer in these other companies. I find the samples that virtual dj has to corny in most cases, like horns and sirens, etc. Also there is no way to preview the samples before downloading them, when I click on the listen button nothing happens. This is something else that needs to be fixed. Looking forward to virtual dj 8 and hope some of these issues will be addressed.
Thanks,
Steve
Thanks,
Steve
geposted Wed 14 May 14 @ 10:46 am
Yes you can use them, in theory.
In practice it depends what format they're in (bit rate, sample rate). Also one big problem in VDJ 7 with using third party samples from packs is that you can't just load them up and have them sync (if they're beat loops). In order for 7 to give them a CBG they have to be loaded to a deck then recorded from there to a sample slot.
The preview on the sample web page is apparently in line to be worked on.
Give VDJ 8 a try. Many more sampler options.
geposted Wed 14 May 14 @ 10:59 am
