DOWNLOAD HERE
A collaboration between Tayla and myself on this one.
A super video skin aimed for use with controllers.
v1.1.0 - 15/05/14
Added optional Rhythm Waveform
As always feedback and comments welcomed.
geposted Wed 14 May 14 @ 9:47 pm
Well done guys, could be my number 1 skin but personally I need the waveform back at the top as it enables me to set the cue points more accurately, can't work without that! Would also like the browser & sample search boxes to be taller but could work without that! Thumbs up for the clock. Go on lose a bit of browser high and bring the waveform back, this is the nearest to perfection for me as a video playing guy.
geposted Thu 15 May 14 @ 9:43 am
Updated added - see first post.
geposted Thu 15 May 14 @ 11:32 am
That's quick Dan thanks. Is there a way to activate the split option?
geposted Thu 15 May 14 @ 1:21 pm
Not implemented yet that. Can be done though.
Which split are you refering to. The one where you have deck 1 above deck 2.
Or where you have two scratchwaves running?
geposted Thu 15 May 14 @ 1:23 pm
One above the other please, on Altern8 you call it vertical split on BlacksheepHD under change wave you call it split.
geposted Thu 15 May 14 @ 2:36 pm
as request screen shots of the clock going, its when its on full screen it goes, thanks in advance for the help, Chris
geposted Thu 29 May 14 @ 5:27 pm
Ok - looks lie the logo is being resized and covering the clock.
Just uploaded a new version which hopefully will fix it - but i can't test on your resolution.
Please download again and let me know whether the issue is resolved.
Thanks
Thanks
geposted Thu 29 May 14 @ 5:46 pm
Its all working perfectly now with the updated skin, thanks for getting back to me so quick and fixing, amazing!
geposted Thu 29 May 14 @ 5:50 pm
No problem!!
Pleased you like the skin!! ;-)
geposted Thu 29 May 14 @ 5:52 pm
