First congratulation on the release of VDJ8.
I tested it and had little bug when switching to fullscreen on the Mac that is the only bug at this stage.
Second i would like you to integrate my Denon 3900 screen into the software same as 7.0.4.
Now this is about being able to control and trigger VDJ with an Ipad while mixing with normal decks.
As you know people are using different gears, if you could add a software even if we have to buy it, connected via bluetoof or whatever so we can trigger samples and drums this will be great.
Anyway thank you for VDj 8.
It was a very long wait
geposted Sun 18 May 14 @ 2:21 pm
Do you mean something like this that works through wifi?
https://virtualdj.com/addons/16130/Performance_Pad_for_iRemote.html
geposted Sun 18 May 14 @ 5:55 pm
Yes, you will need the iRemote App available for the iTunes App store.
geposted Sun 18 May 14 @ 6:21 pm
