Hi,
I have had one of my worries removed already today - moving virtual folders from one computer to another - that is sorted!, but I have another one!
When I move all my music to my new laptop with VDJ8, from a VDJ7 laptop what also do I have to do to migrate all the cue points, beat grid info, file info etc. that I have in VDJ7?
OLD LAPTOP MUSIC SOURCE C:/USERS/DJ/MY MUSIC/80s
NEW LAPTOP MUSIC SOURCE D:/USERS/DJ/MY MUSIC/80s
Thanks,
Thanks,
geposted Wed 21 May 14 @ 8:52 am
I think the best way to go would be to use a external harddrive.
geposted Wed 21 May 14 @ 9:38 am
Well it's an internal external hard drive!
It is a second drive built in to the laptop.
Drive C: is an SSD for Faaast Windows, and drive D: is also built in, but will be a standard HD for the Music.
Thanks,
Thanks,
geposted Wed 21 May 14 @ 10:16 am
Should work fine, VDJ auto fixes/ignores the drive letter... give a try ;)
Ooh! that's clever :-)
Well as soon as the laptop lands in the UK from across the pond - I will try it.
Thank you,
Thank you,
geposted Wed 21 May 14 @ 10:25 am
As long as the path (folder structure) is exactly same, the only difference being the drive letter, you should be fine ;)
geposted Wed 21 May 14 @ 10:40 am
You'll need to copy your database file at least. Things like history are kept in the main VDJ folder too, so copy those if you need 'em.
geposted Wed 21 May 14 @ 10:57 am
