I use the vestax typhoon with Virtual Dj LE. Sometimes a turntable (physical) will still stop working and I have to use the screen to manipulate the songs. One time, one of the turntables was scrolling through the song listings. What could be the problem?
geposted Thu 22 May 14 @ 8:34 am
You can't connect turntables to a Typhoon....
Those small circular discs on your Typhoon are known as platters or jog wheels.
geposted Thu 22 May 14 @ 8:51 am
If the wheel has started scrolling through songs, that's down to mapping. What skin do you use? Some of the skins have a button that toggles through different platter modes like that - maybe you clicked that button by mistake?
geposted Thu 22 May 14 @ 2:28 pm
- thanks for your input, it helped solve all my issues.
geposted Fri 23 May 14 @ 7:25 am
- its the default skin. Im new to using the controller but these issues just randomly started happening. the jog wheel would just not function. Oddly, i downloaded the trial version 8 and it worked fine.
geposted Fri 23 May 14 @ 7:30 am
Happy to educate. :-)
I would suggest resetting your mapping to default - if that's possible in the LE version.
The mapping for JOG should be touchwheel and JOG_TOUCH should be touchwheel_touch
If not, reinstall LE. That should reset things.
geposted Fri 23 May 14 @ 8:01 am
