Ok so I've been busy with v8 and loving it but...Im also bound to find the buggers also....how's this one...I'm editing cue point,so i have now two vdj windows open,correct? I have both windows upper right corner where the "X" is close to each other.I go to close the cue editor and by mistake i close vdj.the editor now stays open and locks up everything.cant open task mngr,nothing! have to force shutdown the computer.this has happen today two times.the other time I had seperated the milkdrop GUI and it stayed open and locks up as well!! no popup saying "Are you sure you want to exit VDJ?"...why?...this is gotta fixed!...and/or if we exit VDJ...so must the sub windows of editors and plugins shoul close with it.please report this guys.its a nasty one...
geposted Fri 23 May 14 @ 12:49 am
Doesn't happen here. I can open an editor window then close VDJ and everything closes.
The window is slightly slower to close than the main GUI but it still closes.
You'll have to give more detail about your system to see if someone can recreate the issue.
geposted Fri 23 May 14 @ 6:33 am
that's not the full picture.is that you dont get a warning popup that you are about to close everything...specs? I've posted the specs many times..cause I have a top of the line Alienware...but here goes...
Alienware m18x laptop/desktop replacement with:
18 inch screen
Intel Core i7-2630QM 2.00GHz/ 2.8 in turbo mode
8GB Memory 1TB HDD (Two 500GB)
dual NVIDIA GeForce GTX 460M in SLI mode
DVD±R/RW
controllers:
mAudio Xponent
Hercules RMX console
Stanton SCS3D (two of them,using a mAudio fast track as a 2nd sound card,along with the Alienware's internal card)
18 inch screen
DVD±R/RW
controllers:
mAudio Xponent
geposted Fri 23 May 14 @ 2:42 pm
btw Groovin, have you checked your trasnsitions lately?....
https://virtualdj.com/forums/188716/VirtualDJ_Plugins/plugings_workin___not___.html
geposted Fri 23 May 14 @ 10:41 pm
well system running smooth...just gotta learn not to close vdj while editing...and i've fixed some of my plugins....nice...
geposted Sat 24 May 14 @ 9:20 pm
this is still a problem.had seperated the Gui for milkdrops and forgot about it when I shut down vdj8 which strangely enough closed quickly without using the xponent's "hold button while closing" bit and I thought "wow! it got fixed!'...then I noticed the Gui still opened and would'nt close..this action should have a warning popup like "window still open"...
geposted Thu 28 Aug 14 @ 3:46 pm
