I have cue points set for most of my tracks. In version 7, tracks would automatically go to cue point #1 (if available) upon loading. In version 8, tracks always start at the beginning of the song, regardless of cue points. Is it possible to fix this? Thanks in advance.
geposted Fri 23 May 14 @ 7:47 am
Are you using a controller?
geposted Fri 23 May 14 @ 7:54 am
change the autoCue setting to cue
Setting -> Options
Setting -> Options
geposted Fri 23 May 14 @ 7:59 am
Thanks djtouchdan.
geposted Fri 23 May 14 @ 1:01 pm
