Hello. I'm really a beginner with this music mixing... I've bought myself a Pioneer DDJ Ergo-V and it worked perfectly fine with the virtual DJ 7 LE it came with.
Now i've bought Virtual DJ 8 and i have a bit problems... I can't seem to click on the buttons "Browser, Sampler, Effects and Record"
And for example my beatgrid just repeats itself over and over again instead of stopping after the 4 "beats"... :-P
Sorry if i'm sounding terribly confusing regarding this topic... I would really appreciate it if anyone of you could help me solving these issues...
Mikkel. :-)
Mikkel. :-)
geposted Sat 24 May 14 @ 10:58 am
You are using an old skin designed for version 7 or below.
Those buttons are not supported any more. Please use a skin designed for VDJ 8.
geposted Sat 24 May 14 @ 11:22 am
Actually that helped alot, but can you help me with my beatgrid ? It sounds a little off, i mean, it sounded very different than when i used Virtual Dj 7...?
geposted Sat 24 May 14 @ 11:28 am
Hi,
First i am happy to see version 8, now i have a problem, i have al mine playlist mated in Itunes, when i open this in VDJ8
is completle mashed up, also i have dubbel numbers, or numbers from an other map, this drive me grazy..
what's going wrong????
Best Regards
Joop Zuurendonk
i am jusing a Mac Pro system 10.9
Best Regards
Joop Zuurendonk
geposted Sat 24 May 14 @ 12:23 pm
bad new about the DDJ-ergo: NO More there having Issues
http://pioneerdj.com/support/product.php?lang=en&p=DDJ-ERGO-V&t=313
geposted Tue 17 Jun 14 @ 11:20 pm
