Forum: Music discussion
Topic: mixing edm
how are people like hardwell able to mix ddm by just cutting into each other, I'm fairly new admittedly but when i try doing that it just sounds awful. would be nice to see how they do it and make it sounds good. i assume they're probably using a loop over the cut between the two?
geposted Mon 26 May 14 @ 6:29 am
Intercity the first thing to know is know your music, (listen to it and find the breaks, the intros, chorus things like that) make sure to beat match. then you can pull off mixing really easy by adding one song into the other with out the low (or bass) just leave the high and mids on and fade in then at the same time cut the bass out of the other song and turn on the bass of the song your mixing in and then fade out by cutting the high first and then the mid....this link is a awesome guide for beginners... https://virtualdj.com/forums/6288/Mix_lessons/DJ_MIXING___basic_-_advanced_-_pro.html?page=1
