Topic: automix points
Hi, I've just discovered the smart automix feature which is great. I see that when using this it displays the two waveforms in the same window and shows the useful automix points for both. Is it possible to listen to each of these when it is automixing to determine if the automix point is in the best place?
Thanks
Jason
geposted Thu 29 May 14 @ 1:44 pm
have a look at the automix editor...there you have the option to prelisten your mix....
Oh really, where...I don't see this option?
hmmm. I dont see this. Im using VDJ 7, where do I initiate the automix editor?
Thanks
LOL...sorry thought you are using V8...;-)
Unfortunately not possible in V7 that´s why it was imroved in v8
OK, I've just downloaded V8 and will explore.
Thanks
on v7, right click on bpm, choose edit automix, then set the point
I had the same problem, thanks.
