Topic: VER 7.4.1 Pro - unable to search
I'm still new to VDJ and editing library, tags, ratings etc... but OFTEN i find when I go to "search" I am unable to enter any information to search. The players still are functioning, and I can scroll thru the library.... I'm confused as to why I can not enter search terms until I restart the program.... HELP PLEASE
geposted Fri 30 May 14 @ 2:59 pm
User Guides give it a try.
been there already, unable to find answer..... but THANKS FOR NOTHING, trolls one of the things I hate about forums.....
I know you said you already read the manual, but page 14 & 15 are good to go back and check that your search settings are checked off the way you want.
https://virtualdj.com/images/pdf/VirtualDJ%207%20-%20User%20Guide.pdf
That being said, after you've renamed your files, try going over to the far left pane in VDJ and expand the desktop icon, then right click on My Computer (This PC in Win. 8.1) and click add to search DB. See if that helps.
Most likely one of the custom plugins that you are using has changed the focus so that you can't click on the search box.
Try clicking on one of the songs in the song list, then back on the search field. Or click on a folder in the folder list, then the search box.
