Topic: VDJ 8: ´Videos without crossfader
Totally brainfreeze!
With vdj7 I know I manage to fix this, now i´m stuck.
I never use crossfader so I Always disconnect it.
Now I cant get the video to automatic change to the channel I using.
Only works if ig by hand set the videofader in the middle , but then It fade a Little on the outsourse.
What should I do to make the videofader automatic work with channel 1-4
geposted Sat 31 May 14 @ 8:26 am
If dont want to use your cf for video try this setting
If you want to control your videofade by volume slider set this
If you want to use automatic video fade, use the automatic button in the videomixer section of V8
