Topic: Independent key problem. headache.
How can i map the LEFT SHIFT, CTRL and ALT keys to work separate from those on the RIGHT side? Before they worked LEFT or RIGHT,now they work as one.
geposted Sun 01 Jun 14 @ 7:00 am
Can someone help with this issue?
Hello kevilev,
Thank you for creating this thread, I have the exact same problem... Unfortunately, our issue doesn't seem to bother the development team...
Team, giive us an answer please.
I have been informed that this is fixed in the latest beta version.
If you don't get beta builds, but want to, go to the settings and set getBetaBuilds=yes
I have just tested it and it works.
Thank you team.
