I'm trying to get my head round action poi's, it will be a while before I full understand what it really means for my mixing but I have figured out that automated mixing/ mash up making is possible right now, it takes a bit of work but it works better than automix.
Here's a brief and simple 3 track, 2 deck example.
Take 3 tracks, and make sure they are sync'd audibly, when the CBGs are sync'd (1 with 2 & 2 with 3)
Use the track cleaner to make a variation of each of the tracks,
Load track 1's variation and find the point where you would like the mix to start.
Make a action POI at this point with this command.
'crossfader 0.5 & deck 1 play ? deck 2 load "M:\Music\Variations\Track 2 Variation.mp3" & deck 2 play & deck 2 sync : deck 1 load "M:\Music\Variations\Track 2 Variation.mp3" & deck 1 play & deck 1 sync'
Add more action POIs to fade, cut, whatever.
Find the point on track 2 variation you want the next mix to start.
'crossfader 0.5 & deck 1 play ? deck 2 load "M:\Music\Variations\Track 3 Variation.mp3" & deck 2 play & deck 2 sync : deck 1 load "M:\Music\Variations\Track 3 Variation.mp3" & deck 1 play & deck 1 sync'
Load track 1's variation.
Press play
Pretend to DJ
Sign for David Guetta
Press play
Pretend to DJ
geposted Mon 02 Jun 14 @ 6:22 am
Making mash ups.
Sort out all your samples and assign them to pads,
Use audacity to create a track of silence however long you want.
Set a beat grid on this silent track with VDJ to whatever you want.
Add action POIs to trigger samples.
Humanly impossible effects
Again make a track of silence, Add a cbg
Go mad with effects action POIs affecting the active deck/master deck/master output/specified deck(s),
Put several of these blocks of POIs on the track with a decent gap between the blocks,
Add hotcues at the beginning of these blocks,
Have this effect firing track on a 3rd deck,
Use hotcues to fire different blocks of effects.
geposted Mon 02 Jun 14 @ 8:12 am
Yup the POI's are stupid powerful!!
geposted Mon 02 Jun 14 @ 12:39 pm
I know, it really hasn't sunk in, but the silent effect firing track means sync'd step filters, gates, rolled time stretch, are all easily possible, And I haven't really thought in depth yet
I'll say it my mind is blown.
geposted Mon 02 Jun 14 @ 1:12 pm
