Hello i try in Virtual Dj 8 to map a A.cue Scratch same in virtual dj 7 and no functionally.
i need help to set this function.
Thanks
Thanks
geposted Mon 02 Jun 14 @ 3:26 pm
Changing it to this worked for me:
touchwheel_touch & var '$acue' ? play ? goto_cue 0 : goto_cue 0 & play
geposted Thu 04 Sep 14 @ 10:19 pm
I think just ...
touchwheel_touch & var 'acue' ? goto_cue : nothing
should work fine. If not mistaken in A.CUE mode, all that the jog does is to return to the last cue point once the Jog is touched. so it wont change the playing status.
geposted Fri 05 Sep 14 @ 2:26 am
I was referring to the A.cue Scratch from here:
https://virtualdj.com/wiki/A.Cue%20Scratch.html
Quote :
This feature will jump to the current cue point when the jogwheel is touched, allowing you to scratch from that point. Once the jogwheel is released, it will jump back to the cue point again and continue playing the song from that point.
geposted Fri 05 Sep 14 @ 10:13 am
