Topic: Wonky VDJ GUI
I have a Think Pad T61 laptop with the recommended 1680 x 1050 as the resolution setting. When I reduce the size of the VDJ GUI with the reduce Square button top right the VDJ screen is cool for a click or two while I drag and drop a file from a folder on my hard drive but then it happens. The left player box gets all crazy spun and doubled over itself with double displays of time, waveform etc. To get it readable again I have to maximize and then reduce again which usually results in the same mess. I tried a couple of different resolutions on the laptop and from the selections in VDJ config. I also use a microsoft mouse. Any resolution or config suggestions would be appreciated. DDT
geposted Tue 03 Jun 14 @ 6:48 pm
