Topic: Mapping question
i use loopout and want to also remove the lows while it loops out...what the mapping for that.
geposted Wed 04 Jun 14 @ 9:30 pm
loop_out & eq_low 0%
like that?
like that?
didnt work...
try reversing ...eq_low 0% & loop_out.
not working either ill just twist the filter knob on mixer
Maybe the mixer is over riding the eq.
The eq knobs on my mixer are not mapped to virtual dj, with the mappings you guys suggested either it just loops out or it cuts the low, but its ok ill try a few things if not ill just use the mixers filter. I have a voxoa M70
is this the loop out effect?
effect 'loop_out' active & eq_low 0%
this worked used the wrong quote marks i guess. But on thing it doesnt stop the track with the eq cut, it continues on after the effect disengaging
I don't have my main machine at the moment so can't text this.
I will take a look tomorrow of Saturday and see if can find the solution.
