Topic: Need URGENTE HELP!
Need urgent help PLEASE!
I have installed on my mac VDJ pro 7 and 8.
in both versions the .cdg files stopped displaying video.
Mp4 flies appear normally, but .cdg not.
Yes i have all cog with the same name that .mp3...
Audio is playing, but video file no.
And it's strange that has happened on both software.
Help!
geposted Thu 05 Jun 14 @ 10:54 am
Bottom left hand corner of the browser. The dot above the two A's. Show karaoke.
EDIT: After rereading your post, you say you are getting the audio from these files, but not the video, from these files. I thought you meant, you were getting your audio files, but not your karaoke files.
If your playing thru a controller, then you need to bring your volume fader up so the video of both can be seen...
Thanks, but now i'm playing it directly on my mac without any controller.
I've noticed that VLC also doesn't play cdg now....
I'm a little desperate!!!! I have a gig next Saturday and this thing doesn't work!!!!!!!
Any other ideas???
Thanks!
Okay, If they are Zip files, create a folder in your desktop, move a couple of karaoke.zip files there and Un-zip them all in that folder.
Start VDJ open the folder and try playing them, If they work, then you will have to Re-zip at a lower rate so the program can open them.
Good Luck
You still have version 7, don't you?
Well... i've restored my computer with time machine to a backup BEFORE installing Virtual DJ8.
It was all working very well.
Then... i've installed Virtual DJ 8... TROUBLE!
That's the problem. VDJ 8 also affects VDJ 7... that's the origin of the problem... I'm again with the same problem.
But the problems only start after running VDJ 8. If i only infall it, but don't run it. Works fine...
There's work to be done to the last version...
Now I'm still in trouble!!!
I need to restore all of it... AGAIN!!
