The way i manage my library. I label and process my files on my desktop the add it to my library. Then i open virtualdj and add to search database the library folder. Then i use freefilesync to mirror my library to my gig machine over my network, then i open virtualdj on the gig machine and add to search database.
My question is there a way to just copy my database file from my desktop to my gig machine and maybe cut out a few steps
geposted Thu 05 Jun 14 @ 4:06 pm
You could add new stuff to your computer, scan, tag and edit everything as needed.
Then plug in a USB device and create a copy of the files on the stick using Virtual DJ browser options.
On your Gig machine copy the files from the Stick to your local drive using VDJs browser.
With this you should keep all Database entries, too.
Greets, Heiko
Greets, Heiko
geposted Thu 05 Jun 14 @ 11:29 pm
Check out this post.
I sync automatically using DROPBOX
https://virtualdj.com/forums/165274/General_Discussion/How_to__Back_up_your_VirtualDJ_folder_to_the_cloud_and_synchronize_between_multiple_computers.html?search=dropbox&page=1
geposted Fri 06 Jun 14 @ 8:07 am
250gigs dropbox not a solution for me ill just keep my same system
geposted Fri 06 Jun 14 @ 9:40 pm
So what is the deal with content unlimited ? using the audio search, entering artist, song, specific mixes, remixes not getting what I am looking for. Is there a certain way of accessing up to date music. Just Checking this product out before I decide to buy the pro. using vdj7. Input will be appreciated. thanks
geposted Sat 07 Jun 14 @ 1:40 am
