Bonjour
je voudrai savoir en moyenne combien faut'il de temps pour faire validé une skin ?
j'ai uploader une skin modifier lundi , et on est vendredi et dans l'état c'est toujours marqué en : Pending review ( examen en attente )
merci d'avance .
merci d'avance .
geposted Fri 06 Jun 14 @ 8:50 am
Hello,
la durée est variable en fonction de temps de dispo de la team.
ça peu varier de 24h à 2 semaines !!
Sinon tu as créé une page de présentation sur le forum des skins ? ça aide en général
Aussi il y a des règles à respecter :
http://fr.virtualdj.com/forums/action/newpost.html?topicid=178298"eid=1539513
djdad wrote :
When you submit a new skin ..
- Provide a proper description in English and describe the functionality of the skin. (E.g. 2 or 4 decks, video or audio, other features that make the skin unique etc). Comments like ..its great, try it.. its unique etc are not considered a description.
- Provide in the description, the resolutions that the skin offers
- Provide a proper screenshot of the skin (200x150), in which the whole skin is visible and not just a part of it
- Select from the Variation field, the skin from which your have used the most graphics to create your own, or choose Original if its a unique creation.
When you update a skin...
We are usually not reviewing the updates of the submitted skins. We only do that when the skins are submitted.
For those who choose to update their skins, please leave some notes in the description about what the update is offering (new features, bug fixes etc)
Add the date of the update too.
Example.
Version 1.2 10-08-2013
- Added this
- fixed that
From now on, if a skin gets updated, and has not the above information in the description, it will be blocked (not available) till further evaluation.
Advice
It is strongly suggested to create a thread in the Skins Forum with the Skin name as title , presenting screenshots and other details, and make it easier for us to notify you when something needs to be edited or changed, prior approving the skin.
Add the link of the thread to the description and help users to find useful information about how the skin works and what offers, prior downloading and searching.
The more information you provide to users, the more helpful it will be for them to find what they need. Unfortunately our website doesnt offer at the moment the ability to show high resolution screenshots in the Plugin Download Pages (most likely, will be added soon), so creating a thread is the only solution for now.
Think as a user who searches the Skin Download Pages in order to find the skin he needs. Dont force him to download something that he doesnt need.
Example.
- Added this
- fixed that
Advice
geposted Fri 06 Jun 14 @ 10:41 am
et comme l'est rappelè dans une autre rubrique anglaise, avant de demander la validation d'un skin, vous devez faire une fiche d'explication de celui-ci en anglais, sinon, nada pour la validation
juan
juan
geposted Fri 06 Jun 14 @ 10:46 am
ah et bien je ne savais pas tout ca .... et bien je ne suis pas dans le caca :x car l'anglais et moi ca fait 2.... :(
geposted Fri 06 Jun 14 @ 11:12 am
met ton texte ici on te le traduira ;)
geposted Fri 06 Jun 14 @ 11:18 am
merci d'avance pour l'aide a la traduction :) ( je ne savait pas du tout qu'il faillais faire un post de présentation en anglais sur le forum anglais pour une skin , et j'imagine que pour un mapper cela dois être pareil ? )
CLASSIC VIRTUAL DARK v0.1a - 2 Decks
Bonjour voici ma 1iere skin / 1iere modification de skin )
il s'agit d'une modification de la skin de default de virtual dj 8 a la quel j'ai modifier les couleurs et les taille de certain texte pour une meilleur visibilité
il s'agit d'une version ALPHA , il peu il y avoir des oublis
skin 2 deck audio et video en 1920x1080
version 0.1a (alpha)
voila en gros ce que je peu dire sur ma skin , vu qu'il s'agit d'une modification d'une skin existante je ne pense pas avoir beaucoup de chose a préciser dessus .
geposted Sat 07 Jun 14 @ 11:42 am
Voici la traduction et une correction de la VF :
___________________________________________________________________________________________________
Bonjour voici ma première skin / première modification de skin
il s'agit d'une modification de la skin par défaut de virtual dj 8, à laquelle j'ai modifié les couleurs et les tailles de certain textes pour une meilleur visibilité.
il s'agit d'une version ALPHA , il est possible qu'il y ai des oublis.
Hello this is my first skin / first skin modification
Here a modification of the default virtual dj 8 skin. I changed some texts colors and sizes for a better visibility.
It's an ALPHA version, it's possible that there have oversights.
2 deck skin audio and video at 1920x1080
Version 0.1a (alpha)
HELP :
Tu remarqueras le HELP à la fin, l'idéal est de créer un topic dans le forum des skins et d'y mettre le lien.
De cette manière les utilisateurs pourrons te poser des questions.
HELP :
geposted Sun 08 Jun 14 @ 6:14 am
Merci beaucoup pour ton aide Dodge57 :)
c'est super sympa
c'est super sympa
geposted Sun 08 Jun 14 @ 7:08 am
pas de pb ;)
geposted Sun 08 Jun 14 @ 7:51 am
