In 7 I would use the sidemix to preset up some songs I wanted to make sure I would play for a gig then save it as a playlist. I don't see a way to save the side list or other lists as playlists. Is there a way to do so or do I have to create them outside of vdj now?
geposted Sat 07 Jun 14 @ 5:00 pm
The automix list still has the 'save' option.
You can also go into the folder list, right-click Playlists and create a new playlist there.
You could then drag it over to the sideview to open and modify it there if you prefer.
geposted Sat 07 Jun 14 @ 11:56 pm
Thanks looks like I just missed it. Found it now
geposted Sun 08 Jun 14 @ 2:05 pm
Even easier, have your tunes in the side list, go to the playlists folder in the folder tree view, find the entry called side list, rename it.
geposted Sun 08 Jun 14 @ 4:22 pm
Ahhhhh
geposted Sun 30 Jun 19 @ 5:30 am
