Topic: Cue Points VDJ 7 & 8
could some one advise me if there is a way to increase the size and colours of the fonts on cue points. Its not too bad on VDJ7 but I have been starting to use VDJ8 today and the cue fonts is very small (it also seems to 'disappear' up into the 'control panal' as per the picture .
Many thanks
geposted Mon 09 Jun 14 @ 11:49 am
It's a skin thing
line 1024 of the 2 deck skin
<group name="waveform" x="369" y="47">
<panel id="defaultwave" group="waveform" visible="yes" >
<rhythmzone mirror="false" upsidedown="false" fade="200">
<pos x="+0" y="+0"/>
<size width="1182" height="92"/>
<colors deck1="#007097" deck2="#8c0709" deck1_active="#009fd2" deck2_active="#cd0f10" />
<rhythm y="+0" height="75"/>
<grid height="6" width="6" maxwidth="10">
<pos y1="+79" y2="+85"/>
</grid>
<cue y="+0" height="92">
<text dx="15" dy="-1" size="14" />
<mask width="12" height="92" x="942" y="1372"/>
</cue>
<overlay>
<size width="2" height="91"/>
<pos x="959" y="47"/>
<background x="1" y="1163"/>
</overlay>
</rhythmzone>
</panel>
Try changing the size on this bit <text dx="15" dy="-1" size="14" />
There might be more to it depending what type of wave you use, but this is very similar to how I did it in V7
Many thanks for the reply - I managed to find the line in Vdj8 skin code and have increased the size of the font.
Next question is do you (or anyone else) know how I can lower the actual 'Cue Text' down a bit vertically speaking (e.g its in the middle of the wave form zone rather than right at the top of it - hope that makes sense !)
Cheers
Sorry just found how to do the position as well now - adjusted the DY= bit on the same line
I am searching for Virtual DJ Pro Full
how can i add effects to vdj8 sample...pls help me tnx!
Hi Jack! make your own thread.
