Topic: Recording Samples from Time Codes
Can you record samples from time coded vinyl, using an external mixer, the same way you can record while mxing internally?
When I try to record samples, using my external mixer, I do not record any sound and the meters do not fluctuate.
I think I was able to record samples off my time coded vinyl in VDJ 7.5.
Thanks.
geposted Mon 09 Jun 14 @ 12:28 pm
should be able to, will test some,but the sample recording should be handled internally i would think
