Hi! I'm planning on buying some form of VirtualDJ software. I'm not sure which I want, but I need software that I can use my controller and soundcard on, that I can play at gigs like school dances and parties, and something that's within my 100$ budget. Also, I wanted to ask what professional use means.
Thanks,
Alex
Thanks,
Alex
geposted Wed 11 Jun 14 @ 2:07 am
To use professionally you need the PRO version, that also has unlimited support for controllers and sound card/sound settings..
You can choose between getting Infinity as a one time purchase, or the monthly subscriber model .. .
See more here:
https://virtualdj.com/buy/
If its not professional gigs, but private parties you do for free, you could also choose the controller version at same link.
This version is limited to one controller.
See more here:
geposted Wed 11 Jun 14 @ 2:19 am
I'm just a hobbyist who mixes for fun and amusement, but so worth, of the budget provides, going all out for the full Pro version - simply because you're future proofing yourself.
Should your controller pack up, and you need a new one (or fancy upgrading to something a little jazzier), it'll work.
When a new version or update is released, its free.
Really, you cannot go wrong. Yeah, its expensive, but a one-time shell-out can't be knocked...
Mike.
Mike.
geposted Wed 11 Jun 14 @ 12:13 pm
yeah true, on a long term consideration, and if planning to do gigs and dj more professionally, the PRO Infinity is a good choice ;)
geposted Wed 11 Jun 14 @ 6:06 pm
