Is there a way to write that filter so it includes tracks with half of the bpm value and double the bpm value?
geposted Sat 14 Jun 14 @ 6:11 pm
do you use V8 ?
if so, have a look to the new libary tool
https://virtualdj.com/addons/16760/My_Library.html
the are a lot of various filter and examples. so you can personalize you own specific filterfolder.
geposted Sat 14 Jun 14 @ 6:32 pm
Yes I have vdj8 and I've downloaded the my library tool. (Great tool by the way!) I was just wondering if it was even possible to include those tracks with bpm readings that are half or doubled. Example. If I'm playing a track with a bpm of 120 and I select the compatibility folder could it also include those bpms that are listed at 60.
geposted Sat 14 Jun 14 @ 7:16 pm
just try to set a different bpm range
geposted Sat 14 Jun 14 @ 7:27 pm
