Hi Guys,
this could be a stupid question, but here goes.
I want to purchase VDJ 8 controller license for my pioneer controller, however i use the software on my laptop and desktop pc, does the license work only on one computer or will it work on my laptop and desktop? i believe it will be only one or the other, but i wanted to check first so i install it on the correct machine.
thanks in advance.
thanks in advance.
geposted Mon 16 Jun 14 @ 4:10 pm
geposted Mon 16 Jun 14 @ 4:33 pm
will work legally on both machines, dont worry...;-)
geposted Tue 17 Jun 14 @ 6:46 am
In the EULA: "It can occasionally be used by guest users, or it can be used by one user on two computers, but it cannot be used by two different people on two different computers at the same time."
I have two laptops. One for LIVE use and the second is just a backup in case of laptop crash.
I'm at work now and really want to test some things (and look at skins) since I got more time at work than at home :)
At work is another laptop... That would be the third machine if I install VDJ.
May I install VDJ on the third machine as "testing purpose" ? (This is without connecting my controller since I'm not bringing my controller to work)
This is especially because I really want to check out the Silver Sleek skin that came out today :)
geposted Wed 06 Aug 14 @ 3:48 am
No problem...
https://virtualdj.com/atomixproductions/EULA.html
Right at the top ;)
EULA wrote :
1. PERMITTED USE AND RESTRICTIONS
You are granted one license to:
- install the Software on as many computers as you want, but;
- run the Software on a maximum of two computers at any single time, provided that they are at the same physical location and operated by the same person.
Right at the top ;)
geposted Wed 06 Aug 14 @ 3:53 am
Right at the top ;)
Right at the top ;)
Oops... :S
Thanks PachN! :)
geposted Wed 06 Aug 14 @ 3:59 am
